Warn XD8000I
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ChevyCaGal, Apr 14, 2001.
  1. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Hey...I was thinking of buying this winch. It's a new Warn xd8000i includes everything. Never opened still in box, roller fairlead and all, $550 firm, will ship for $75. It's for sale in the parts section...is this big enough? I was thinking might not be? I'd love to get a 12,000lb one but I can't afford that! Is this a good price too? I know I see them for about $710 or so with free shipping on sites so I think it is....thanks!! [​IMG]
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have the xd9000i and i wish i would have goten the hs9500i buy the way i got my xd9000i for only $440 brand new but it was from a private party
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    What is the diffrense between the two??????
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    the xd9000i is a 9000lb winch the hs9500i is a 9500lb winch and the hs stands 4 high speed so the hs9500i is faster. when you see 9000i and 9000 the i just means 125ft of cable the standerd is 100ft of cable
  5. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    sounds worth it to i havea older warn 8000 upright and i have only powered it out once and that was becosue i run one battery and stock alternator i paid $500 for min wiht a winch bumber it was used like 3 time befor but i got it from x-girlfriend's dad but if you get it get snach block then you wont ever have a problem
    Bandit
    (Your right i dont understand the jeep thing)
  6. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Ok, That makes sense. I could see wanting the 9500 lb. And the 125 cable. But I don't think I really need the high speed. Other then It realing up faster not a big deal...........Dan
  7. bandit
    Mar 4, 2001
    690
    sometimes id like it by hell my 8,000 does fine i was doing some major thinking on it i guess it was twice i powerd it out once i pulled a ext cab dodga (sp) 24 valve up about 10% grade in 4 feet of snow powered it out doing that and then i powerd it out the other night when i ad the blazer vertical and had to go streight up about a foot in 4 1/2 feet of snow but like i said i think with dual batterys and high out put alt. id be fine
    Bandit
  8. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I dunno, I havent personally seen anything 8000 or highter for less than like 600-700 on ebay. I'd love to get a winch too, but that means a new bumper as well.. well, here's the other thing. Do you really need 8000 lbs of dead pull power? I mean a pull block will effectively double your pull power to 16000 lbs.
    Well, anyways, if you see a winch cheap, I'll take it. :)
  9. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    As long as you have enough line to make a double line pull its fine. Even with 125' of cable if you are more than 50 or 60 feet from the truck you might need a single line pull, and depending on how stuck you are an 8000 might not do the job.
    I've always heard you should have a winch rated at twice the loaded weight of your truck, so anything in the 9000 lbs and up catagory.
    I would grab a smaller than ideal winch if the price was right though...
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
