Warn XD9000 wiring question
Discussion in 'The Garage' started by Jamus, Oct 13, 2003.
  1. Jamus
    Jamus Registered Member
    Jan 10, 2002
    29
    Morgantown, WV
    I got a used winch and need help with wiring it. It had one bad selenoid(replaced) and all the lines cut on the control box. Does anyone have a wiring diagram for a Warn XD9000? I think I have it wired back together correctly from pictures off the internet but want to double check. I think I have everything figured except the main ground wire that runs to the neg. post of the battery. Where does this go; winch body, winch mount, control box on one of the selenoids? Thanks for any help.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I have an XD9000, the ground cable grounds directly to the motor case, you should see a bolt hole on the rear side that it will attach to.
  3. Jamus
    Jan 10, 2002
    29
    Morgantown, WV
    Well, I think the guy must have lost the bolt that goes into the case. I felt around the back and didn't feel any studs. The guy mounted it on a winch bumper with the bottom and fairlead mounted together. Therefore the back is now the bottom. But I have to take it off the Ramcharger it's mounted on anyway. I'll check it out with it off. Thanks or the reply.
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    There is not a stud but rather a tapped hole for a bolt to go in. Look for it, it should be there.
  5. Jamus
    Jan 10, 2002
    29
    Morgantown, WV
    Alright, I'll check it out as soon as I can. Tonight was the last day of my 4 day weekend. So, I might not get to check it out till next week. But anyway, you've been a lot of help. I've been running to every offroad site and asked with little success. So thanks. Let ya know what I find.
