Was the 3rd seat an option?
Discussion in '1936-Present Suburban' started by BurbinOR, Oct 25, 2002.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    I see some ads saying 'no third seat'..............does that mean it was optional? If it was, and if a truck didn't have it, is there still the mounting capability to put on in easily?
    Getting closer to Subville................. /forums/images/graemlins/laugh.gif
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    I don't know about the later models, but my 1977 GMC Sub didn't have a third seat and no provisions (internal mounting brackets) for it. /forums/images/graemlins/burb.gif
  3. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    It will really depend if it came from the factory with one. Other wise I know some people have one out of a universal van. Most conversion companys who do subs order them with out the third and put in there own. These subs were called grand prix's. So if you can't get a burb with the third seat you can always mount one out of those trucks. /forums/images/graemlins/burb.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, the 3rd seat was an option. Adding it later can be expensive. Junkyards usually want a small fortune for those seats because they know that people looking for them really want them bad. /forums/images/graemlins/angryfire.gif I'm not sure if the seat mounts are hiding under the carpet of those rigs that were ordered without a seat. So check around for seat prices and the hassle factor before you buy one with the back seat missing. Around here I've heard that the seat can go for up to $750. /forums/images/graemlins/eek.gif So I made sure that I bought Subs with the rear seat already there! /forums/images/graemlins/thumb.gif
  5. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    The 78 we are purchasing does not have the caged/welded nut under the bed that our 77 had for its third seat. I am sure because I crawled under to look for them specifically. I am going to put a third seat in. I do not consider it a big deal at all. They just need appropriate reinforcing of the area of the bed floor similiar to what the factory installed. It also works quite well using a newer folding suburban third seat, if you make up some simple brackets to adapt from the rigid back seat mounting configuration - we did this for the 77. I have bought entire sets of suburban seats front , middle, rear - newer 81 up style, for $500. You can find the older non-folding third seats needing recovering from $50 up.
  6. JAXSTER
    JAXSTER 1/2 ton status
    Mar 15, 2000
    181
    DFW, TEXAS
    IF not Factory option No Mounting Provisions. Still in effect /forums/images/graemlins/burb.gif
  7. Scrubby
    Scrubby 1/2 ton status
    Dec 1, 2001
    114
    Boise, ID
    My '77 did not come with a seat nor did it have the mounting brackets in the floor. I picked up a junked '83 sub for $200 that had the seat and the mounts. I cut the rear floor area out of the '83 where the mounting brackets were. Then I cut small holes in the floor of the '77 where the brackets would hang down. Then I put the piece of floor down on top of my existing floor and welded it down. It is strong and under the carpet, you can't tell at all..
  8. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    That was a good idea. /forums/images/graemlins/thumb.gif
  9. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    your suburban may not have the mounting brackets, but I'd like to assume it'll only take drilling holes, adding a reinforcement plate under the floor, and welding a nut to the hole in the floor. the floor design is the same, except for the lack of holes, so adding one shouldn't be anything hard at all.
    -Rich
