Was there ever a GM dana 70?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kickinasphalt383, Mar 20, 2002.
  1. kickinasphalt383
    kickinasphalt383 1/2 ton status
    Dec 6, 2001
    224
    Michigan
    Did GM ever use a Dana 70 front axle in any of its trucks... such as in the front axle of a 1-ton dually? Or is it always a D60 in a GM?
    Also how do you tell the difference between a front D60 and a D70 front?
    thanks
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Dana 60 9.5" ring gear
    Dana 70 10.25" or 10.5" ring gear (cant remember exactally, but one of the two)
  3. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    I'm not sure about the older pre '73 body trucks but from '77 through the end of the straight axles, GM has always used a D60 front in the regular production trucks. Even in the dually's the front was always a D60.
    I've been told that some of the mid 90's 3500HD trucks (telephone and power company type) had a D70 front but to the best of my knowledge those trucks are not factory 4WD.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Dana 70 rear came in duallies.
    Dana 60 is 9.75" ring gear
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    OK wait...
    I thought the
    Dana 60 = 9.5" ring gear
    14 bolt FF =10.5" ring gear
    Dana 70 = 10.54" ring gear
    so the dana 70 ring gear is only slightly larger than a 14 bolt full floater.
  6. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    OK, one more time, here it is:
    Dana 60 = 9.75" ring gear
    14 bolt FF = 10.5"
    Dana 70 = 10.54"
    Yes the Dana 70 ring gear is only slightly larger than the 14 bolt FF (the 14 bolt SF has a 9.5 inch ring gear), but the Dana 70 (and 80 for that matter) have the same size axle shafts (1.5 inches) as the 14FF.
  7. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    i think you can gain some ground clearance with the 70 too...
  8. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Okay I was close. It was off the top of my head.
