washer pump improvements ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beater74, Nov 26, 2001.
  1. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    on my 74 the wind sheild washer just plain sucks, it shoots these two lame a$$ squirts every second or so that don't do a hell of alot to get mud or just plain old dirt washed off the window. i have replaced athe the lines and cleaned the nozles. I am think'n about in stalling an elec. pump on the stock tank and wiring it to a switch on the dash, i look'n for dumpage i mean gallons per minute well not that much. So what have you done to improve your washage?
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    they have after market pumps, I don't know how well some work but my pump pooped out so I got the 10 dollar one and it works OK they had some that were alot more expensive so maybe they worked better...
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It could be that your pump is just worn out. You can buy replacement parts for them. Your pump is attached to the wiper motor and is driven off of a cam. When it's working right, it should squirt 2-3 times per second, with a pretty strong stream. FYI, DO NOT buy the pump rebuild kit from the "Help!" line of parts that most parts places carry. The plastic they use is inferior and deforms quickly. Buy a brand name kit (Anco is one) and you won't have to worry about it again for another 20 years. [​IMG]
  4. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    Another alternative is to upgrade to the later model ('85-'91) wiper system. As near as I can tell, it's a straight swap. I am doing this on my '73 Suburban. My wiper motor and washer pump were dead, so I got a new wiper motor, washer jar and washer pump from LMC Truck.
    The '85 and up trucks use an electric washer motor to pump the fluid which provides a much stronger, steady flow. It should be pretty easy to find the parts at a wrecking yard.
    Robb
    '73 GMC Suburban - 502DFI
    <a target="_blank" href=http://community.webshots.com/user/robbrj>community.webshots.com/user/robbrj</a>
  5. dyeager535
    26,979
    I'd just add that I'd stick to the older non-wiper mounted "squirters" if you swap wiper motors. Have to take the cowl piece off to re-attach the hose if it comes loose on the wiper mounted ones. Man is that frustrating : )
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  6. 502Burban
    Jun 8, 2001
    379
    Southern California
    As usual, you're absolutely right, Dorian.[​IMG] That's exactly what I'm doing. The wiper mounted squirters are a pain, so I'm just changing the motors and jar.
    As a side note, I discovered this weekend that my steering column is no good, since it has obviously been in a wreck and collapsed, so I just picked up an '85 column from a wrecking yard to replace it. Now I'll have the turn signal lever mounted wiper controls with the delay box. I figured if I was going to replace the darn thing, may as well upgrade.
    Unexpected side-effect though, is that I need to change the mount at the top of the intermediate shaft to the double-D type instead of the splined older style.[​IMG] Oh well, nothing comes easy that's worth having. At least that's what I keep telling myself.[​IMG]
    Robb
  7. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    If you get a lot of mud and salt grime, hot water through system works great. I took mine and hooked it up to a fuel filter that I mounted next to headers. Dam hot water and cleans great. Only thing to point out, don't mount to header as it boils water, don't ask me how I know?
    If you ain't hurt, you ain't playin' hard enough.
    The General
  8. dyeager535
    26,979
    Apologize for hijacking the post, but I have a question about the column. You mention it collapsed, and you need a new one. Where and how did it collapse? Someone told me that the columns were designed to collapse, (as in the metal actually shifted) but as far as I can tell, thats in the steering shaft itself, thats why the nylon is in there, no steel.
    I know on my '67 Firebird column, the "jacket' was actually perforated metal, that would crush on impact, and THAT would be a disposable column, but even having had a '73-up truck column apart, I've never seen anything besides the nylon that shears off inside the shaft as a "collapsing" section. I collapsed mine just tinkering with it, but pulled the shaft back out and have used it ever since.
    Dorian
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wish mine would only work. That would be a major improvement.
    Tim
  10. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Chevy columns are telescoping (but not 1st gens). They are made of 2 pieces of steel that are glued to gether. DO NOT HAMMER ON IT!
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  11. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I bought a inline elec. pump for mine (it is called like a universal kit or something like that) I just haven't put it in yet.
    When I replaced the elec. pump in my mom's car it would shoot the fluid all the way over the car! It was also kinda fun to get your friends wet when they were walking up to the car[​IMG].
  12. 502Burban
    Jun 8, 2001
    379
    Southern California
    When I bought the Suburban, it was obvious that it had been in at least one solid wreck. This weekend I removed the steering column so that it would be easier to replace the ignition switch, turn signal switch, and neutral safety/backup switch.
    After getting the column on the workbench, I noticed that the mounting points for the bracket that mounts the column to the dash had broken their epoxy seal and slid back about 3/4". This is generally a bad sign and an indication of something causing the column to compress
    Upon further inspection, I also noticed that the collar that houses the turn signal switch and lever had shifted and come into contact with the turn signal lever. The lever had actually caused the collar to crush about 3/4" where they had come into contact. At this point, after throwing a few tools,[​IMG] I decided that I didn't want to rely on this column anymore.
    After tearing it down even further, it became apparent that the bearings weren't in the best of shape, so I packed it in and went on the hunt for a later-model column to install in its place.
    Dorian, if you (or anyone else) are interested, I can snap a few photos of the damage and post them for you.
    I also apologize for hijacking the post, but maybe someone will find this info helpful.
    Robb
  13. beater74
    May 29, 2001
    1,749
    atlanta
    darn hijackers. hehe thanks for the help.
  14. Grim-Reaper
    7,385
    Atlanta
    You can use the stock wiring. If you look at the wiper motor at the top there is a plug with 2 wires. That's the squirter power off the stock switch. Just get some spade plugs and you can tag it without cuttings. Works great.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  15. beater74
    May 29, 2001
    1,749
    atlanta
    yeh i think i'll do some search'n for some sort of inline pump.
  16. Grim-Reaper
    7,385
    Atlanta
    Most parts stores have them for like $12. Previous owner replaced the washer bottle with one that had a electric on it. I think the wires your looking for are Brown and white. Have to meter them to figure out what one is power. It the wires right at the top. the other wires come in at the bottom
    75 Jimmy, Dollar
    Grim-Reaper
