washing under hood
Discussion in 'The Garage' started by XHitman396, Jun 6, 2003.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    after muddin, im sure everyone has all that crap covering the engine compartment, ive heard both good and bad about using the power washer thing at the local Spot-Not-Car Wash, what damage could i do?? thanks
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    mostly you need to make sure you don't get any water in the carb or distributor other than that you should be ok i wash mine all the time with one /forums/images/graemlins/thumb.gif
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I've never used a pressure washer but I do use a high pressure nozzle on the hose. I figure anything that gets water in from the hose probably needed to be sealed up better anyways. /forums/images/graemlins/thumb.gif </font>
  4. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i'd also lube the hood latch and all. i spray white lithium grease in the creases of my hood also, ilive in michigan where they dump a ton of salt every 1/4 mile even if it flurries.
