wasting my time?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chris77k5, Dec 15, 2001.
  1. chris77k5
    chris77k5 Registered Member
    Nov 26, 2001
    19
    washington,puyallup
    All i see on this borad is everyone talking about there 14bolt or there dana 60 conversons am i wasting my and money by putting gears and posi's in my stock running gear? I want a too drive it every day and go wheelin on the weekends but i dont want it brakin all the time. thanks for the help.
    77 k5 400sb, edelbrock rpm, carter 625,4" rancho 3" body, 3.08 10bolt 12bolt 33-12.5 soon to be 4.56 and 35s bfg km
  2. Grim-Reaper
    7,385
    Atlanta
    Well here is the issue. For what it will cost you to regear the back axle you could buy a 14 bolt with a Detroit used. If your seroius about going to 35's it might be something to concider. Now that still doesn't fixs the big problem...the front. If you lock the front it's just a matter of time before you blos a shaft. Leave it open it will do ok. Now if you convert to 14 then you also need to figure in the cost to conver the front to 8 lug and new rims.
    That said I still run the half ton gear with 4.10 a Detroit in the rear and a lockright in the front. I'm easy on gear. 35's it will do ok but I would carry a spare rear axle shaft. If you had a 10 bolt I would say scrap it go for the 10 but since you have a 12 they hold up better. Also a 12 with35's will have more ground cleanece then a 14 on 36's heck probably more clearence then 37's.
    Just need to really put some thought to what your going to do with the truck. If your positive your not going to go bigger than 35's...the stock 1/2 ton gear will probably do fine.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  3. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    What kind of wheelin are you doing?
    Bo
    If it breaks, it wasn't good enough!
    http://coloradok5.com/gallery/liberator
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Like Grim said look into the cost of everything. I went 1 ton because I plan to run 38's soon. Not counting cost for tires, it cost me $1700 for axles and wheels. Just to upgrade the stock 10 bolts would have cost that much with parts and labor.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  5. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    And 1 other thing, even upgraded the 10 bolts would not have been as strong.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    how hard are you going to wheel? i am converting mine (already got the 14ff in just need to get the dana 60 in febuary) because i blew my 12bolt apart in thesand[​IMG] it wasent even locked just had a posi unit
    wheeling videoshttp://community.webshots.com/user/ssmith6333
  7. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Really depends the plans for your rig... I have been debating the same questions. Basically if you don't do rocks you can probably get away with more. Tire size, motor power, etc. also come into play. Also if you plan to run a locker then breakage is gonna be more prevalient then open. You can beef up a 1/2 ton with aftermarket axle shafts, either steel caps and arp stupds for the carrier or a reinforcing diff cover to keep the gears from deflecting. Also aftermarket gears are stronger most times then stock GM ones.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  8. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    So Grim,
    What you are saying is that 12 Bolt will hold up with 35's and light wheeling???? I have been considering an axle swap. But so uninformed...............
    The Few, The Proud, The K5 Blazer
