wat should i do?
Discussion in 'The Garage' started by Pow06er, Jun 25, 2005.
  1. Pow06er
    Pow06er 1/2 ton status
    Apr 9, 2005
    188
    ne, ohio
    2.5 " lift and 33s
    4" and 35s
    with stock wheels and axles and 3.42s on a '88 k5?
    99% DD 1% fun
    My original plan is the 2.5" lift with 33x13.50x15 toyo open country mt's
    but now that i found out about the 3.42s i might go with procomp or tuff country 4" and cheap 35" mts
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    if your sure its 1% fun go with 2.5 and 33's unless you want to do other mods, i.e. gears
  3. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    say its once every one or two months id go mudding or something
    Im not keen on the highway driving with 35s for some reason on an old blazer
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    3.5 with springs front and rear, 35's and trim the fenders but have a body shop roll the fenders back to a factory edge. get the aditional 1 inch with a zero rate frotn and rear move the front axle to the front 1 inch and get your steering correction with a drop pitman arm.
    truck should drive GREAT, look GREAT and perform fairly well off or on road. you could still tow ligh loads. you would have to re-gear it though. 4.10 would be closest to factory i think...
    Grant
    EDIT, i saw your "not to keep driving on the highway with 35's" part. Eurethane bushings in the springs, maybe the body and some BFG all terains would be just fine on the highway. if you are not off road much i belive the 315/75 series (on a 17 inch rim its a 35 12.5 17, but im not sure if they have a 15 inch in the 315's....) has an 8 ply tire so it would be a stiffer side wall and be GREAT for the highway. you can always bump the pressure up to max and highway handling would be just fine. PLENTY of older blazers and trucks on the road with 6 to 8 inches of lift and 35's.
    Grant
  5. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    i like fender whell so 4" kit now with 33" tires and later wou will be set for bigger tires. just a idea. as most of the kits are the same price for 2 or 4. and you will not see much with the 2" kit as with the 4" kit.
  6. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    i dunno im debating
    I plan on swaping in a 14 sf i have laying around and using it
    if i got with 33's ill prolly go with toyos if i go 35s it will be cheapies possibly dunlops
    i will be keeping stock 15x8 rallies
    also will i get bad bump steer if i do a 4" and use the 4" steering arm?
    its quite a difference between the 2.5" cepek for $275 or a about $570 for a 4"
  7. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    Throw on a 4" or 6" with 35" tires. Buckshot Mudterrains are great for a great price. It drives nice on the highway too!
  8. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    i have a 14sf with 342s that i think im gonna throw in it and then im gonna prolly run dunlop muds about 120 from tirerack
  9. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I'm with you - 4" and 33's for now. If you go with 2" you will wish that you had the extra 2 later.
  10. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I have 4" w/ 33's and I think it looks great. I doubt i would ever go w/ 35's cuz im 99.9% DD and .1% fun. I don't want to scratch it. :blush:
  11. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    4" of lift with 33s doesn't look to bad. If you're looking to save $, you could always use a shackle flip in the rear and used 4" front springs. People going to 52s/56s tend to have them FS cheap. AFA tires go, you might consider ProComp ATs. They are decent tires and have a 50k mile guarentee (prorated Im sure, but better than nothing!).
    j
