Water coming through my passinger side firewall..
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JohnnyFresno, Oct 16, 2002.
  1. JohnnyFresno
    JohnnyFresno 1/2 ton status
    Mar 24, 2002
    194
    Clovis, CA
    Well I replaced my heater hose a week ago or so and since then I have noticed water leaking underneath the passenger side.. Also my carpet is wet like a mofo and up in the firewall?? area it is soaked as well.. what the [censored] is wrong here? and how can I fix it ,, thanks.
  2. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    You probably damaged your heater core.
  3. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    The heater core is probably leaking. kinda a PITA to change but not that bad.
  4. JohnnyFresno
    Mar 24, 2002
    194
    Clovis, CA
    Thanks for quick response I thought it was that at first but wasnt sure.. I will try replacing it asap..
  5. Grim-Reaper
    7,385
    Atlanta
    Hehehe Well if it's rain water it's a leak in the cowel box. Open the hood and look at the fire wall. You will see a seam running the width of the truck and it goes under the AC/blower box. The water coming in from the vents at the base of the windsheild will leak through the seam into the A/C/Blowe box and get into the inside box from there.
    Skigirl had a heck of a time tracing this problem down and that's what she found. I'm not sure what she used to seal the seam but I'm sure she will see this post and fill you in.
  6. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Just be glad you're the driver.
    /forums/images/graemlins/tongue.gif
    Replace the heater core.
    If it'll be awhile before you can do that and you need to drive the truck now, you can easily bypass the heater core. Instead of running one line to the core and one line back from the core, just hook one line from the water pump back to itself. Pretty cheap too.
    -- Mike
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Grim could be right, make sure it's not rain water first, and then if it is te heater, try the radiator sealers first, it worked with mine, and saved me the hastle of changing it /forums/images/graemlins/smile.gif
    It's only a couple of bucks and then if it doesn't work, you will change it.
  8. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Yea, that was a pain. Wouldn't have found it without Grimmy's help either. I sealed the cowl with a silicone sealer that remained fexible and was waterproof, found at home depot. But I think there's probably better stuff out there at auto shops. At some point I'll go over it again, just to be anal. /forums/images/graemlins/thumb.gif
