Water in fuel problem solved
Discussion in '1982-Present GM Diesel' started by Espen88k5, Mar 12, 2001.
  1. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    I had a problem a while back with the WIF light comming on when accelerating. Turned out to be a cheap fix. Just replaced the box-filter on the fire-wall and all is good again. Turned out the filter has a hole for a sensor-pin in it, this pin tells the wif light that there is water present in the filter. Had I gone the Haynes-manual route I would have ended upp terring my entire fuel system apart. Pays to ask the dealer first. They where clear and presice in theire advice: Replace the fuel-filter every spring or once a year at least.
    Just thought I'd post this for you other tractor-drivers.
    <A target="_blank" HREF=http://www.espen88k5.coloradok5.com>http://www.espen88k5.coloradok5.com</A>
  2. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Back in my 6.2 days the wire for the sensor in the tank developed a problem that causes the WIF light to come on at times when there was no water in the tank. Solved the problem by replacing the WIF and Glow Plug lights with a check engine light.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  3. NewK5Guy
    NewK5Guy 1/2 ton status
    Mar 2, 2001
    556
    Alexandria, VA
    Actually, you could have just drained that water out.
  4. Espen88k5
    Feb 19, 2000
    981
    Norway
    For S&G I drained the water from the filter into a clear plastic container, to see what was in there. It had been 1,5 years since last filter change, and I found lots of small particles in the filter. I guess I could have emtyed it and put it back on, but it only takes one pinhead-size piece of crud to make it a expensive trip to the dealer. The filter was 20$. Cheap insurance.
