WATER in T-Case?
Discussion in 'The Garage' started by blackblazer717, May 18, 2005.
  1. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    you know how everyones case leaks and if it dont than their is no more fluid to leak from it.
    well my tail shaft seal seeps a little and i noticed this morning that it looked like dunkin donuts
    poured a large regular down the fill hole cause it looked like coffee with cream and sugar
    coming out my tail shaft. does this mean i got water in my case?
    LUKE
  2. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    yup....
    Water + Oil = mayonaise looking goop!...Either you got the T-case deep enough in a puddle to allow water in thru the vent,or its condensation due to our wonderful temparature swings here in MA..
    .I'd drain it out and flush it with kerosene or diesel fuel--( fill it and run the truck with the T-case in neutral at low RPMs)then dump it and refill it with the right lube(some take 90W gear oil,some take dextron ATF, depends on what T-case you have--the full time NP203's use motor oil)...its hard on bearings when they get rusty from water in the oil,and its not a good lubricant after its contaminated with water...get it out ASAP... :crazy:
