Water in the hubs!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Esteban86K5, Mar 16, 2001.
  1. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I just went off-roading this weekend and was doing a lot of water crossings. I took my hubs apart to do my brakes and had all kinds of water come out of there. I've been driving the truck everyday since I went off-roading so I would have thought that the water would evaporate. How do I keep the water out? It can't be good for the bearings.
    Any suggestions?
    Esteban
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Try replacing the little o-rings on the cover bolts and use Marine grease on the bearings as a extra precaution
    Murphy's Laws on Life :
    "Opportunity always knocks at the least opportune time." [​IMG]
  3. flcpl4fn
    flcpl4fn 1/2 ton status
    Jan 9, 2001
    194
    Florida
    Another thing, make sure your wheel bearing seals are good. And there is a little rubber seal where the axle comes into the spindle, check and make sure that one is in good shape too.
    '85 Jimmy in Jax, Fl
  4. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    The water will not evaporate, it will mix with the greese and fianlly kill your wheel bearings, hubs, and then that ususally causes spindle damage at the least.
    Take both front wheels off and the rotors and clean them out and clean and re grease your wheel bearings, put in new grease seals (and bearings if they are bad) then replace the orings on your locking hubs.
    Any time you do water crossings that are deeper than your hubs you need to check and re grease the front wheel bearings when you get dont with your trail ride and get home.
    Depdog
    <font color=blue>Weenie K5, little mods' Small Tires!</font color=blue>
    <A target="_blank" HREF=http://depdogsk5.coloradok5.com>http://depdogsk5.coloradok5.com</A>
  5. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    I had the same problem, forgot to check the bearings after numerous water crossings on a trip and the right front wheel ended up locking up at 60 mph on the hiway. Now i'm parting my truck out.
    Squash
    <A target="_blank" HREF=http://www.trailrunners4x4.org/users/realsquash>http://www.trailrunners4x4.org/users/realsquash</A>
  6. highboy
    highboy Newbie
    Mar 18, 2001
    I had problems with water getting into my hubs until i started using hub helpers. you can find out more at http://www.hubhelpers.com
  7. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
  8. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    I think maybe duct tape might work, too.
    "Rage WITH the Machine!"
  9. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Heres a pre-trail run tip...
    Use clear silicone from hardware store. Lock in your hubs, then silicone the area around the hub and hub case. Next smear some silicone over the hub to rotor surface. After wheeling, you can easily remove the silicone... Always check the hubs after deep water crossings over the hubs.
    Mudzer 1978/91 K5
    <font color=blue>www.mudzer.coloradoK5.com</font color=blue>
  10. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Awww...shower caps for the wittle bwazers! how tweet!
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You know, I've seen those little rubber caps somewhere before. Junkyard supply? If we could figure out another *common* source, I'll bet a pair with hose clamps would be well under $30...
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  12. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    I have auto-locks on my 91. I took the cap off with the 6 screws holding it on. The "O" rings on the screw looked ok and the large rubber ring around the hub looked ok. To lazy to get some new ones. I put a bead of clear silicone around the hub rubber ring and some on the screws also. I'll find out if it works next time I'm in the water.
