Water is dripping down the pass. side kickboard I cant pinpoint it.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Apr 8, 2001.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    Is this a common problem? Its been raining for weeks and the floor is pretty wet now. I can see the water tracks on the surface of the plastic kick panel but I cant tell exactly what needs to be sealed up. Thanks.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    I had a similar problem once. Turned out the windshield weatherstrip was old and had cracks all over it. Had to install a new weatherstrip.
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I had a couple of trucks that had the same type leaks. all from the windsheild. had them sealed with a little urethane and all is well.
    your right. I don't understand the jeep thing!
  4. shum1
    Oct 8, 2000
    270
    UTAH
    Thanks, should I seal it from the outside?
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I had leaks on both corners.
    I got my windshield completely re-sealed and the passenger side still leaks...[​IMG] Now I've got to find the time to find where it is leaking and try and do something about it. I wouldn't mind carpet of some sort one day, I just want to make sure there are no leaks first!
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  6. Flyinhi86
    Flyinhi86 Registered Member
    Mar 31, 2001
    51
    Ft McMurray, AB, Canada
    Either the seal bad or your sill is rotted/rusted out, might want to consider popping out winshield.
  7. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Had this problem too. New windshield seal, sealed with a ton-o-goop. Found that the passenger door seal (angled portion) was getting water past it, running down the channel (that part that clips over the sheetmetal lip) and then running out on the inside right at the point where the seal turns straight up and down on the hinge jamb (as the metal lip turns, it is crinkled). It would run into the dash/jamb junction then down on the side kick panel. Drove me crazy trying to find it. When I was driving, it would get worse, and just sitting, it would drip. Fixed it by pushing the seal off of the lip from bend to bend and laying a bead of windshield sealant on that length.
  8. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Hey Wheels, you probably saved me a few days of head scratching! I'll check that out...
    Rene
  9. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    also check out the airboxif the drain is plugged it ll overflow or leak out thru a seam in the box.or its rusty.pull back the carpet,and run a water hose over the windsheild,try your best to see where its comin in.it can be a bear to locate sometimes.thats in addition to checking the window seal and doors.
    PURE INSANITY
    86 blazer silverado 400 horse 350 w/vortec heads 38 x15.5 swampers (40 hawgs next)10 bolts(blah)w/4:88s coming soon,14 bolt.
  10. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I thought I could fix mine, the seal was a little raised, put a 2x4 up against the seal, hit with hammer, and windshield broke...insurance covered, told the glass guy about the leak and he put this black stuff stuff around the seal that he told me was made of the same stuff as my tires (rubber?!?!?!). Sealed it up pretty well, no more leaks. you should probably pull up the carpet to clean up the wter and stop rust. Just don't get lazy like me and leave the carpet out for a month.
    90K5
