Water leak -HELP - It's Raining...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Mar 15, 2001.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Water leak -HELP - It\'s Raining...
    It rained all night here in Washington. I got in my truck and had a puddle on my drivers side floor under the emergency brake pedal. It's done this before but it's bad, really bad now. It isnt coming from the door or and seal I can see... Somewhere under the dash... Seems to be dripping off somewhere under the dash... I cant find the leak and It's ruining my week old carpet... HELP!!! Any ideas... I havent done a thing inthis area of the truck...
    Um... yes officer I know it's too big...
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Re: Water leak -HELP - It\'s Raining...
    Could be the window seal or running down the A pilar. Or, it my be leaking from the cowl. Look down in there. You may need to dig out leaves and such. It could be simply cracked and leaking or it could be rusted out.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    It's your windshield gasket. There's a channel behind it so if water gets in there it will rust and make a hole and leak behind the dash. I just ran a bead of silicone around mine and it worked.
    Murphy's Laws on Life :
    "Opportunity always knocks at the least opportune time." [​IMG]
  4. reddog64
    Nov 9, 2000
    3,325
    So where do I put the silicone at???
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    If it is the window gasket and rust, you don't. You need to pull the window, kill the rust, and fix the hole. Anything else is a temporary patch waiting for more expensive damage.
    Bad Dog
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    It is the windshileld. I has three leaks in my windehield, so I pulled the whole thing out. Cleaned back there with paint thinner to remove the grime and then had 2 leaks. I broke my windshield trying to fix it, and insurance covered it, the glass guy put some rubber glue stuff where the gasket meets the glass on the outside and it worked really well. No leaks. I also removed my carpet and found a lot of water sitting down there and a small amount of rust.
    90K5
  7. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    I put the silicone on the outside. Around the outside edge and inside edge of the gasket. Also, this a temporary fix, as Baddog said, and you should fix the rust as soon as possible
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Looking back at my earlier reply, it didn't come out like I meant it to. Certainly, till you get time the silicone can help although it may be hard to get it to stop. Just don't forget to actually fix it when you can or you will wind up with serious problems in a year or two.
    Bad Dog
