water leak?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nc87k5, Apr 29, 2004.
  1. nc87k5
    nc87k5 3/4 ton status
    Sep 23, 2003
    5,231
    North Carolina
    ok, can someone point out where the main areas for a water leakage, without any visible signs? I filled up my radiator last week and it was about 10 inches low yesterday. I just had the water pump replace several months ago and can't see anywhere that it is dripping. suggestions and what signs to look for?
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Heater Core
    Check the oil for water/antifreeze
    Any white smoke in the exhaust?
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    radiator, hoses, frost plug, head gasket cracked head, cracked block.
    look for white smoke in the exhaust, this means your burning coolant, ie: blown head gasket, cracked head or block /forums/images/graemlins/crazy.gif
  4. nc87k5
    Sep 23, 2003
    5,231
    North Carolina
    getting some smoke on the first crank, seems to be a little blueish/white. I know some might be the valve seals. I'll double check it tomorrow.
  5. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    If your shure you aren't losing any water through a leak then like stated above I would be watching for white smoke. Another thing is are you adding antifreeze when you refill the rad? Antifreeze has a wonderfull habit of wiping the bearings clean of oil if you indeed have coolant in the oil. I would get strait water in there ASAP if you see milky looking oil on the dipstick.
  6. nc87k5
    Sep 23, 2003
    5,231
    North Carolina
    /forums/images/graemlins/thinking.gif, checked the oil and hadn't noticed it being milky so I'm assuming it's not going there. thanks for all the suggestions, I'll see what's going on hopefully after I get the grass cut tomorrow.
