water leaks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by myklnglo87K5, Aug 22, 2001.
  1. myklnglo87K5
    myklnglo87K5 Registered Member
    Aug 22, 2001
    10
    Kent, WA
    Hey out there. I recently purchased an 87 K5 Blazer, and to my dismay found out water leaks in on the front floor from under the kick panels. Does anyone know if this is a common problem, or have had similar seapage and know the likely source? I've removed the kick panels and couldn't tell where water might be coming in from. Any suggestions would be much appreciated before I start tearing in to things.
  2. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Check the gasket around the windshield. Also check for rust right below windshield.
