Water neck problems...please read
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, Jun 7, 2001.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I went to go buy a new thermostat tonight and I also bought a chrome water neck. The one on my truck now is not painted the right color and its old and nasty. Problem is the neck of the new one is facing straight ahead to the front of the truck. The older water neck on the truck points farther over to the drivers side. So the hose won't match up right with the chrome water neck. I really don't think they make any aftermarket neck with a turn like I need. Do you suppose I can find another upper radiator hose that matches up better? Or should I just return the chrome one and repaint the old one???
    '73 K5
    Chevy good...Ford bad
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You could use a flex hose, or if you really want to keep your original molded hose, Summit Racing sells a swivel thermostat housing in chrome, or any color you want anodized aluminum. <A target="_blank" HREF=http://www.summitracing.com>http://www.summitracing.com</A>
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.coloradok5.com>http://pugsley.coloradok5.com</A>
  3. '73 K5
    1,763
    Kansas
    Are those flex hoses as strong as the molded ones?
    '73 K5
  4. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    you should be able do get a chrome water neck the comes off at an angle to match your old one, i have one on my 73 right now, i got it from pep boys, its a MR. gasket brand and i think it cost me around $10. they would probably have them at any parts store, the one you got is probably for a 60's chevy
    Check out my 73 K5 http://members.theglobe.com/xnoahx/73k5.htm
  5. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've used them with no problems - One thing to make sure is that you use good, preferably new hose clamps.
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Look around, you can find a chrome one with the correct outlet. They are everywhere.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  7. Grim-Reaper
    7,385
    Atlanta
    I have one at the correct angle I picked up at Auto zone on my 75.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    I am sure you can find the right one for that... Also, Summit sells ones that rotate to the angle you want!
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  9. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    You can get one with the correct angle - I got one from Kragen. Just make them look in their book...
  10. '73 K5
    1,763
    Kansas
    Thanks for the help everyone. I just went down and found the angled kind like I needed. It was there the whole time, I just didn't see it yesterday.
    '73 K5
  11. dyeager535
    26,979
    Try a radiator hose for an Olds, say a 1985 Olds Cutlass Supreme, V8 307 (5 liter) They have forward facing water necks. Easier than replacing the housing and gasket again lol Actually it may be way too short, but couldn't hurt, you can always return it.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
