Water Outlet
Discussion in 'The Garage' started by anjieandjohn, Nov 7, 2005.
  1. anjieandjohn
    anjieandjohn Registered Member
    Oct 31, 2004
    61
    Virginia Beach
    I had to replace the 4 port vacuum/Temp switch on the water outlet and now want to replace the other thingamagig too....what is the other thingamagig called? I know it has one wire that comes off of it and goes to the carb (for choke things i assume). It has a temperature element in it but I dont know what it is called. Thanks for the enlightenment.
    :confused:
  2. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    sounds like a tvs...thermostatic vaccume switch
  3. dyeager535
    26,975
    I've forgotten the name, but its something like a secondary accelerator pump. It's been covered a bit before here, but it's a one-off setup really.
    This is assuming you are talking about a carb with the two wire connector on the passenger side top, with no connector on the front drivers side. That two wire connector is where the one wire you mention goes?
  4. anjieandjohn
    Oct 31, 2004
    61
    Virginia Beach
    yeah...one goes to that switch on the therostat housing and the other goes back to somewhere on the passenger side.
  5. dyeager535
    26,975
    If I remember how that setup was wired, it is just a switch.
    You might check out LMC's catalog, they seem to have a pretty good selection of all that thermo controlled emissions stuff.
