water problems
Discussion in '1982-Present GM Diesel' started by odee, Sep 2, 2002.
  1. odee
    odee Registered Member
    Feb 5, 2002
    15
    Big Stone Gap Va
    I have been losing water in my 6.5. The engine had new head gaskets and bolts prior to install. Would run about 4 or 5 days needs enough water to turn off low coolant light. I pulled heads back off to check for bad gaskets no blown spots. Heads are at machine shop now being checked for cracks in the exhaust ports. Oil wasn't milky looking, did have some moisture in the oil fill cap, is that normal? Didn't find any leaks to the outside of the motor. Are the blocks bad for cracking? This is a 98 model motor.
  2. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    you sure that there isn't a hole somewhere in the cooling system that is allowing water to seep out? Seems a bit drastic to immediately assume cracked head or block.
