WATER PROOF INTERIOR
Discussion in 'The Garage' started by CHEVY 4WD, Jun 18, 2002.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    What do you guys do for interior? like floors and stuff how do you make it water proof like the said the did on TRUCKS with the blazer has anyone tryed spray in bedliner I would really perfer somthing removible if possible
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Mine's Rhino lined. Mud and dirt can be hosed out. One of the best mods we have ever done.
    Check out my pics.
  3. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Just make it hoseable, use one of these urethane bedliners, its a little louder in the cab but worth it
  4. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    I used Rhino, just make sure they spray it on extra thick in the trans tunnel area if you have an auto. It will help keep the heat down.
  5. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I used herc and wet okie seat covers. Pics on my site below. Need pics of the new seats though. They aren't on there yet.
  6. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    does the rhino bedliner make your feet slip? or a rubber mat slip?
  7. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Herculiner the whole floor so you can hose it out when muddy!
    Kool /forums/images/icons/grin.gif
    Bill C /forums/images/icons/cool.gif
  8. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    im going to rhyno line my k5 sometime next winter.looks like the way to go for a 4x4.never will rust again if you do bottom too
  9. trailblazer87
    Jun 11, 2002
    707
    Madera, CA
    If you do the bottom just make sure it is CLEAN!! Anything under there will cause it to not stick and possibly peel and rust, that would be about impossible to find.
  10. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    My self I'm getting a rubber/vinyl floor from JC whitney. It's removable and keeps the sound and heat down and is water proof to a point. I still have doors and good seals so i'm concerned about traking stuff into my truck not so much on being open to the elements.
  11. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    first...remove anything that can soak up water, ie. carpet, seats, headliner, doorpanels. replace with plastic, rubber, rhino liner, or vinyl. next...remove anything that can be damaged by water, ie. radio, guages. replace with marine type guages and radio cover. last...look for the biggest pond you can find! /forums/images/icons/grin.gif
  12. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Only problem with that is any water/moisture that gets under the mat tends to stay there. Might be a good idea to paint w/ POR-15 or at least Rustolium, 1st.
  13. chulisohombre
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    sounds like a plan.can we take your rig???haha
