Water Proofing A K5
Discussion in 'The Garage' started by hawkeye649, May 19, 2006.
  1. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    I was trying to find a comprehensive list of stuff to do to water proof my truck, and I found some stuff but not quite what I was looking for.
    I found alot of posts saying things like breather tubes for the diffs and t-case tranny, some die electric grease on the plugs, and the odd snorkle or way to make it more snorkle like.
    What I am looking for, is there anyone out there who knows how to get the rig military water proof. I'd like the passengers to need a snorkle before the truck starts complaining...
    Is there anyone here who uses a positive air system for their differentials like the hummers do? Would this work for the transmission, t-case, and distributor (I have a 90 w/ HEI)?
    Would gauges croak when submersed? I've read that they still work after getting rained on... but?
    Just don't like "loose" ends good enough. Always drives me nuts in life...
  2. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    T T T
    Is it just me or is it gae that TTT auto-magically get's the last two T's lower-cased when posted...
  3. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    HMMWV's do not have positive pressure sytems to keep water out of the diffs, tranny/t-case, or geared hubs- just breather tubes. All electrical connections on military vehicles have a rubber boot on them to make them water proof and the engine is a diesel so it eliminates all of the problems with sealing the ignition system. I have only had a HMMWV in water that deep once and when I came out two of my gauges had water in them. I don't think I have ever had a HMMWV where all the gauges worked anyway.
    I think its 5 ton and up trucks that have positve pressure systems on the axles and such
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Maybe a swamp buggy forum (if one exists) would have a better handle on it. Water proofing for a dunk here and there is one thing, making it amphibious is another.
  5. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    I've heard of putting rtv/ silicon on the distributor cap to help keep moisture out but I don't know if it works or not, haven't tried it yet. I'm still waiting on rain to take my truck muddin'. NM is dry :( .
  6. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    siliconing the dist cap on does work, but the cap is supposed to be vented. a non-vented dist cap causes the air inside to ionize(splg), which can & will cause it to cross fire inside the cap, so it is not a long term solution
  7. K5TRLBLZR
    K5TRLBLZR Registered Member
    Mar 31, 2003
    52
    Elk Grove Ca.
    How about a marine application. I had one of those duel point jobs back in the day. Never did put it on though. LOL
  8. diesel4me
    Jul 24, 2003
    17,568
    942
    Massachussetts
    florida swamps..
    Those "Swamp Buggies" they race in Florida had some kind of epoxy stuff from the phone company all over the cap and base of the distributor..it must work,because the jeeps run completely submerged!..I've seen rubber gloves used on 4 cyl dist.caps!..maybe you can google "swamp buggies",and borrow some waterproofing tips from those guys..:crazy:
  9. resurrected_jimmy
    May 23, 2005
    2,241
    A friend of mine has a truck set up for deep mud and we sealed the dizzy as you said and then built a vent tube for it that run inside the cab. We also moved the coil and batt. and air cleaner inside the cab. His truck will run underwater.
