Water proofing my HEI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by deek, May 26, 2003.
  1. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    I want it sealed up and plan on doing RVT or silicone around the base, But my main problem is condensation. can you put a breather on a distributor? if so how, or is it even needed. also what should i use to seal up my plug wires. Please /forums/images/graemlins/1zhelp.gif
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    why do that ?
    ive never had a probolem with water and HEI
  3. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    yes, you have to vent it to let out the carbon from the contacts. otherwise you'll need to change cap and rotor with every oil change....or so ive read
    ryan
  4. getitup
    getitup Registered Member
    Apr 27, 2003
    35
    Hazelwood, MO
    I have heard of people sealing up their cap and then running a small vacuum to it so no condensation will build up. I have never tried it so I am not sure how well it works.
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yes, you will need to run a vent line of some sort from the distributor if you seal it.
  6. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    THe third post is right..
    Seal a HEI and you will have nothing but problems..
    40-50,000 volts, arcing from the rotor to the contacts produces lots of "ionazation", the "air" inside the cap gets conductive, just like a fluorescent light bulb...
    You will get all kinds of problems, from missfire to crossfire
    You are better off, drilling .040 holes, near the top of the cap on the side, between the terminals, to "vent" it..(old drag race trick).and letting engine heat keep it dry.. Shield it with a rubber boot if you get alot of splash... get one off a 5.0L Ford from the mid '80's up...
    Speaking of Ford.. They HAVE a vent in the cap, just for this reason...and the boot to shield the distributor.. and their distributor is in the front...take a look
    /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
  7. dyeager535
    26,982
    191
    My '88 TPI has a vent as well, but its a mesh screen at the base of the distributor. Those of us that don't run Fords don't have to worry about water splashing on the distributor nearly as much. /forums/images/graemlins/smile.gif (only joking folks)
