water pump and front oil seal on 97 1500 with 5.7 vortec
Discussion in '1992-Present Chevy & GMC models' started by k5ntexas, Oct 30, 2002.
  1. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    is it hard to replace those things on the newer vortecs? is there alot of crap in the way? my dad wants me and a few of my buds to do it. he'd pay us but he dont' wanna take it to a mechanic. dont' feel like spendin way too much money. just askin if its any different than any other older 5.7. later.
    jacob
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I just replaced the water pump on our '94 Sub. It isn't a Vortec, but it has the serpentine belt system. None of the accessory brackets were in the way! /forums/images/graemlins/cool.gif I pulled off the upper half of the fan shroud, then removed the fan, then removed the belt. Then I just had to remove the 4 bolts that hold the water pump in place. Installed the new pump and put it all back together.
    You'll need a few special tools to replace the front oil seal. You need a harmonic balancer puller to get it off the crank. Then a seal puller to get the old seal out of the timing cover. Try to find a piece of pipe that is the same diameter as the seal housing, to use to drive the new seal in place. Then you'll need a harmonic balancer installation tool to put it back onto the crank. DO NOT hammer on the harmonic balancer to reinstall it. You can crush the thrust bearing surface inside the engine, which will result in too much crankshaft endplay. Not too long after that you'll get to rebuild the engine. /forums/images/graemlins/shocked.gif
