water pump help!! *DELETED*
Discussion in 'The Garage' started by RAY, May 31, 2004.
  1. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    Post deleted by RAY
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Re: water pump help!!
    did you remove the 4 little bolts that hold the fan and clutch assembly on the water pump?
  3. RAY
    Jul 4, 2000
    281
    Austin, Texas
    yes, I have removed the four bolts that mount the fan to the clutch and the four bolts that mount the pulley to the pump.
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    should just come off, you may need to tap it a little bit. /forums/images/graemlins/dunno.gif
  5. RAY
    Jul 4, 2000
    281
    Austin, Texas
    Its not threaded on? The replacement has threads.
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    what your describing is a Ford,Jeep,some Chrysler style water pump, i didn't know they changed them over to that, you should have loosed it up while it was still on the engine and the belts were still on it.
    It's a PITA otherwise
