Water pump/leak?? Question??
Discussion in '1982-Present GM Diesel' started by dallassnowman, Mar 17, 2005.
  1. dallassnowman
    dallassnowman 1/2 ton status
    Sep 14, 2003
    339
    Forney, Texas
    Noticed antifreeeze bubling out where green circle is, in the corner. The pic is behind water pump (driver side). Question is ..Is this a spacer behind the water pump??(white arrows). The bolt in the picture above is to the water pump.
  2. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    anyone ever replaced a water pump on a 6.2????????:confused: :confused:
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    The water pump is mounted to a plate that bolts in between the timing cover and pump. You have to remove the pump attached to this plate to get to half of the screws that come in from the back. This means you have 2 layers of gaskets to leak/seal.
    If you are going to replace the pump or at least the gaskets, now would be a great time to plan on replacing the timing chain set if you have over 100K miles too.
  4. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    thanks for the info...how hard is changing the chain??
    Also when removing pump bolts will the time chain cover come off too??
  5. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    my 6.2 leaked from the same exact spot, all i did was remove the PS pump bracket, and tighten the nut. now she doesn't leak at all and i didn't even use sealants.
  6. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    Ok I'll give that a try...thanks for the reply.:thinking:
  7. kennyw
    Jun 9, 2002
    13,224
    94
    Be very careful with this approach. I cracked a water crossover housing in the middle of nowhere (Wyoming) on vacation once trying that meathod to fix a small leak :doah:
  8. savagek5diesel
    Nov 20, 2003
    310
    Redding California
    It wasn't like i just torqued it down, the SOB was very loose, like 4 water pump bolts were hand loose, along with a 10 other bolts on my engine. my truck seems to vibrate it's self apart.
