Water Pump Q?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MILOLGJC, Mar 23, 2003.
  1. MILOLGJC
    MILOLGJC Registered Member
    Sep 27, 2002
    29
    FL
    I purchased and installed a Bosch water pump into my 76 K-5. Got the device from PEP boys...well it wasn't until after I had it all bolted in that I noticed an opening in the top center portion of the pump above the impeller housing. This opening appears to be about the size of the heater hose fitting that is secured to the top of my engine block, The opening is about an inch in diameter and threaded. There were no plugs included to plug the hole. I called PEP boys and they said the other pump in stock had the same hole. How do I plug this hole???? Thanks. The parts technician...(kindly put)suggested I find a brass plug from a hardware store. Augh!!!! /forums/images/graemlins/mad.gif
  2. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    use a plug or get a heater hose fitting and run one of your heater hoses to it, and plug the other hole, All SBC water pumps have this hole,AFAIK
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    they arent gonna provide you with a plug with them cuz normally theres a hose port fitting screwed into them, but some trucks dont use that and use radiator hose port instead, so just go to hardware store and get a pipe plug to thread into it
    good luck
  4. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    yep, it's 1/2" NPT, so go to the harware store and get a 1/2" threaded plug, warp it with teflon tape, and screw it in.
  5. MILOLGJC
    Sep 27, 2002
    29
    FL
    Thanks! /forums/images/graemlins/laugh.gif
