Water Pump Question ASAP
Discussion in 'The Garage' started by Hossbaby50, Mar 29, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am replacing my water pump right now. I need someone to tell me that those 2 little holes in the pump body are supposed to be there and be unblocked. The holes are about 1/4 in diameter and are right above and below the pump shaft. One on top and one on bottom. The water pump I just pulled off had one on the bottom and it was unplugged so I assume this is supposed to be like this correct? Thanks
    Harley
  2. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    They do not need to be blocked, they are weep holes. If they ever have liquid come out the seal is shot.
    John
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes they are suppose to be there. i was thinking the same thing then i asked the guys at the auto parts store. they are there to let you know that the water pump is starting to go out. they will be leaking with coolant when it is bad.
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    That is what I thought. I believe that is where my old water pump was leaking from, so I thought it was supposed to be there. I just got the project done. Thanks for the replys. I appreciate it.
    Harley
