water pump replacement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beat'83, Oct 12, 2002.
  1. beat'83
    beat'83 Registered Member
    Sep 28, 2002
    7
    delanco, n.j. 08075
    how tough is it to replace a waterpump on a 305?
    looks like a bitch.
    any help appreciated /forums/images/graemlins/confused.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/confused.gif
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    The hardest part is keeping all of the vacuum lines and emissions crap sorted out. You do have to remove the PS pump. Use masking tape and put a piece on both ends of a connection with a 1,2,3...etc it makes putting everything back together easier.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    When I did mine, I had to remove/pivot/loosen every accessory bracket off the front of the motor, because for some stupid reason GM has them all threaded into various locations on the water pump /forums/images/graemlins/angryfire.gif. If I remember correctly, the PS pump was the hardest. I believe there's a hidden bolt on the PS pump bracket.....
    I have no emmisions stuff in the way, BTW. Just take your time and step-by-step. You should also consider replacing all your belts while everything is apart.
