Water Pump
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wakedog, Sep 12, 2001.
  1. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    My truck has been leaking anti-freeze and i am about 99% sure it is from the water pump. My question is how much do they cost and are they hard to install or not?? Thanks in advance.
    <a target="_blank" href=http://www.bigredjimmy.iwarp.com>http://www.bigredjimmy.iwarp.com</a>
  2. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    you can usually get a remanufactured with warranty for less than $60. New one is not alot more $ usually. They are easy to install. A few things to watch for. unhook hoses. take 4 small bolts loose for pulley/belt, remove 4 9/16 bolts that hold waterpump on. scrape gasket material carefully off of block. make sure area around holes on block are clean. put silicone on bolts when reinstalling waterpump because 3 of the 4 bolts enter water jackets on the block. torque bolts. can't remember how much torque right now..can get back to you on that if needed.put the pulley,belt and hoses back on and ride and look to make sure not leaking. not hard to do at all.
    Neil H. Alabama.. "It's a full size thang, Jeep owners don't understand!!" '78 K5 400ci 4x4 AT,AC,PW Cheyenne., '74 C10 4x2
  3. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    on my 74 400 it's simple, you neglected to say what it's on, and how much "technology" it has.
    Tork DSR
    I just got a winch, it takes the fun out of things.
  4. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    You gotta 350??? the pumps 28 bucks new w/ lifetime warranty at napa... 4 bolts on the pump itself... just gotta get al the belts and fan off... dont hit the radiator... it's 160 new... plan 2 to 3 hours... let the rtv drie before putting water back in... and seal it good... lotsa rtv...
    [image]http://www.inhomenetworking.com/images/littleblue.jpg[/image]See me at <a target="_blank" href=http://www.inhomenetworking.com/78jimmy.htm>http://www.inhomenetworking.com/78jimmy.htm</a>
  5. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    yeah!!... I hope he doesn't have an LT1 in his rig!!! or LS1, they both are a B!7Ch on water pumps!!
  6. wakedog
    Mar 7, 2001
    233
    Minnesota
    Ive gotta a crate 350 but it is just the normal one so to speak. Tomorrow im goin to change the lower hose and see if the leak was from that. If not i will replace the water pump. Thnaks for the help.
  7. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Yup waterpumps are cheap. I recomend getting a new one for a few dollars more (I sound like an infomercial salesman [​IMG] ). I like the Borg Warners for aftermarkets and AC Delcos. If you need a hand don't be afraid to ask.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  8. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Replace all your belts while its apart!! Cheap insurance.
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
