Water temp gauge question? 1979 K5 blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BozoWise, Apr 28, 2002.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    My water temp gauge is not working and I have just added electric fans and removed the mechanical fan for water crossing adventures. Where should I start to look for the problem. I would figure it is the sending unit or gauge as all my other gauges work fine. Should I just forget the factory gauge and install a new gauge? I would like to get the factory gauge to work unit I have time to build my new dash, at that time I will be replacing all my gauges.
  2. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    Most of the time it's the sending unit, they go bad all the time. If the guage just sits at the coldest spot, I'm betting it's the sending unit. If you take the wire off the sending unit and ground it out, the guage should move or peg on the hot side. If it doesn't move, then you need to look into wiring or something else. But 99 out of 100 times it's the sending unit. Hope this helps.
    Ben 87 Jimmy
    <font color=blue>Rust=Bad</font color=blue>
  3. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    That sounds like my problem, but where is the sending unit on a 1979 sbc 400? Thanks in advance
  4. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Its on the driver's side head between the #1 and #3 spark plugs. It will have a green wire going to it.
  5. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    THANKS going to replace it now ;-)
  6. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    It is amazing how well the gauge works when the wire is plugged on the sensor ;-)
  7. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Hahaha, I've done that. My oil pressure gauge was pegging out when off and I figured sure enough that the sender was screwed. I had a dirty contact and I guess the pressure gauge works the opposite as temp, full reading when not hooked.
