Water Temp Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CrazeeBush, Apr 20, 2000.
  1. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    Okay here's the deal, my truck was running like 230 degrees and I replaced the Water pump and the thermostat. It runs cooler, but I still don't think it's right. I put in a 195 thermostat and my truck runs 210-220 degrees. It runs hottest while I'm driving, but when I pull up to a stop light it drops to 210. Anybody have any ideas for me? I'm really stumped. Could it be timing? Maybe a clogged radiator, or a bad fan? I'd really appreciate some input on this one.
    Thanks in advance,
    Josh
  2. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
  3. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
    Yah, stock fan shroud....
  4. hpfire7227
    hpfire7227 Registered Member
    Mar 14, 2000
    75
    Holland Patent, NY
    back to basics...check your coolant level...hey, you never know.
    10 BOLTS O' FUN
  5. 88Jimmy
    88Jimmy 1/2 ton status
    100
    Las vegas, NV
    what type of gauge are you using stock??
    I went out and pick up a scanner from Schucks for 160 bucks
    it reads the computer and my stock gauge lies like a big dog!! I watch my gauge goto 210 then down midway to 100*
    and the scanner shows 198 to 204. I watch the gauge drop coming off the freeway but the scanner show the temp is going up.
    The scanner is AutoXray EZlink
    350 Vortec TPI D60 14Bolt 4"lift 35 BFG A/T
  6. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    Ok you have A TBI motor with a 195 therm that means your motor will run at 210 which is bad on 700r4 trans and seems to high but thats life ,what you need is a 185 therm it will drop the temp and you will still pass smog fine,the reason for the high temp is it gets better smog levels at higher temps so it runs high.I have a 91s10 and my 88k5 both did this now they run about 190 maybe.
  7. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
    OKay, Here's some info on my truck maybe that will help. Yes I have a stock guage, and I'm not sure that it's right so I'm gonna check it against another guage. It's an '83 K5 with stock Q-Jet carb. 700r4 trans if that's anything to ya. Anything else that I might check?
  8. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    ive was having the same problem. my gague was reading 245 at 75mph, turns out the gage is off by 30 degrees. now im running hotter that its warming up, i did a water pump last year, tommorow im doing a radiator it was only $179 at pep boys which is cheap insurance. the dam things just get old and cloged.
  9. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    Yeah i just upgraded my radiator to an 4core. It will be worth it when summer hits..
  10. NYC K5
    Apr 3, 2000
    185
    i did my radiator this morning and my temp droped 30 at highway speed, the old one was so corroded that when you touched the fins most of them pushed right out.
  11. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
    Thanks, looks like a new radiator is gonna go on my truck. :)
    (Unless my guage is bad) Anyone have any probs with bad fact guages?
  12. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I think all of the factory gauges suck. My oil pressure goes up to 60+ PSI sometimes, then drops to 10 or so. The temp will run up to 240 deg. and stay there occasionally, but I'll tap the gauge face or hit a bump and it 'll drop to 190 or so. I'm just gonna ditch the old ones and go with Autometers.
    [​IMG] Semper Maintenance!
    [​IMG] So many ideas, so little money...
  13. Blazerbob
    Blazerbob 1/2 ton status
    214
    Western NY
    I put a Hi-flow water pump on my 83 and a 160 thermostat and now she runs around 165-170. It used to run around 210-220 and I didn't like the trans getting that warm
    <font color=blue>Blazerbob</font color=blue>[​IMG]
  14. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    My new free catalog from pace parts has some very nice looking guages that will go in the dash. Mechanical type not electric like what is in there, and you can get them in white face if you like... Semper Fi
    <font color=blue>http://www.paceparts.com
