Water Temp Sender
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Rob71Balzer, Sep 5, 2002.
  1. Rob71Balzer
    Rob71Balzer Registered Member
    Jul 24, 2002
    6
    Colorado Springs CO
    Anybody know where to find the water temp sender? My buddy was helping me time the thing and I think he kicked a wire loose cause it don't work now. Also anyone know where I can get a pair of the caps that go on the top of the vent window? I would like new ones if possible.
    Rob 350/SM465/NP205/D44/GM12b
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    If it's stock should be on the side of the driver side cylinder head between plugs 1 and 3. Wire color is green.
  3. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    You can get the vent window caps from Chevy Duty. I think They still have a Banner ad on the top of the screen. Jim hit it head on with the sending unit. If it is not there look on the water neck in case it has been changed from stock.
    John
  4. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    I believe the name of the part you are looking for is called a drip rail deflector and the Chevy Duty part number is 01-713, they are $24.95 a pair.
    John
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    my temp sender is on the passenger side between the 6&8 cylander.maybe mine was ran different.
  6. JIMs70K25
    Dec 31, 2001
    524
    Chesapeake, VA
    I believe there are plugs on both sides of the motor. I have one where your talking about.
  7. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    The heads are the same so they use them on either side. If you took the oone off of the left side with the sender between 1 and 3 and put it on the right side it would be between 6 and 8. The one between 6 and 8 is where I hook up my electric fans.
    John
  8. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The part that you are talking about is not the "drip rail deflector". There is no aftermarket source for the caps that go on top of the vent windows. The only option is to try to find a used set.
  9. Rob71Balzer
    Jul 24, 2002
    6
    Colorado Springs CO
    Hey thanks for the help everyone.
  10. chulisohombre
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    Re: Thanks
    i bought a parts blazer on ebay just for the top and luckily it still had the caps cause mine were missing.i havent found an aftermarket company that offers them yet.
