water temp sensor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by burbnthedsrt, May 9, 2002.
  1. burbnthedsrt
    burbnthedsrt Registered Member
    Dec 19, 2001
    7
    arizona
    Does anyone know where the water temp sensor is on an 83 sub? My gauge doesn't work so I've got to find the sensor. Thankx
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Look on the driver's side between the front two sparkplugs (#1 and #3). There will be a green wire going to it. Try to groud that wire out on the manifold and see if the gauge pegs out. If not, then you have a cut in your wire, or a bad gauge.
  3. burbnthedsrt
    Dec 19, 2001
    7
    arizona
    Thanks for letting me know where it is. Only problem is the idiot who owned the truck before me ran a junky temp gauge under the dash to that sensor no green wire. Help!!!!!!!!!!!!!!!!
  4. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    It is gonna be in the same spot.
    unless it is a mechanicle gage it will have a wire going to it.
