water temp sensor?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by therover87, May 28, 2002.
  1. therover87
    therover87 1/2 ton status
    Jun 24, 2001
    139
    Long Island, New York
    i have an 87 k5 350 tbi and i was told to replace my water temp sensor but i am not sure where that is
  2. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    The water temp sensor is the sensor right next to the thermostat housing on the top front of the motor. That tells the computer what temp your motor is running at. If you want the water sensor for the guage it is the sensor on the diver's side bank between the first two exhaust ports. Hope this helps.
    Ben 87 Jimmy
    <font color=blue>Rust=Bad</font color=blue>
  3. dyeager535
    26,975
    You might want to make sure its the problem before replacing it. Apparently they do fail once in awhile, although I've never had it happen.
