Water Temp
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rem7600, Apr 28, 2000.
  1. rem7600
    rem7600 1/2 ton status
    Apr 16, 2000
    125
    Coeur d\'Alene, Idaho
    Hey All,
    On the way home from work today I noticed the Temp guage
    go to 200 and then dropped back to 175ish. Rig is quite
    new "to me" and seems to be running hot. In the 190ish
    range most of the time. Is this above normal?
    Truck has an oil cooler in addition to a tow package
    from the factory. Other info needed?
    <font color=purple>REM7600 - '89 Jimmy</font color=purple>
  2. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Rem, sound pretty much normal for that year Blazer, if you notice it hanging around 210 alot swap out the thermostat, and have the raditor cored anf flushed
    <font color=red>White Knight</font color=red>
    May the dirt rise to meet you and the wind be at your back always.....[​IMG]
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    My 87 does the same thing. When I tap on the gauge face, the needle drops back down to 180-190. I feel the factory gauges are cr@p, so I'm installing Autometers at some point.
    [​IMG] Semper Maintenance!
    [​IMG] So many ideas, so little money...
  4. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    thats more than ok. the hottor you run the more efficient you run to a point. plus the factory gagues arent that accurate. try placing an accurate thermometer in the radiator inlet and establish the basline that your gague is off
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    200-210 degrees is pretty normal for later model fuel injected engines, though I would recommend replacing the thermostat as it sounds as it might be sticking a little.
