waterproofing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BPCRJ, Apr 29, 2000.
  1. BPCRJ
    BPCRJ Registered Member
    Apr 29, 2000
    12
    Is it possible to completely waterproof the cab of an 80's model chevy full size Blazer 4x4. Maybe by stripping everything down to the sheet metal repairing all rust spots and holes then going over every possible seal or opening with silicone then instead of carpet put down some spray down bed liner. These are just some ideas I thought about. But what about the doors? Also what do you think about putting two bilge pumps under the seat to pump any water out the back. Another thing, is it possible to seal all electrical wires in waterproof tubing so as not to short stuff out in water holes. I live in Mississippi, so not many hills to climb but lots of thick mud. ANY advice you have on these thoughts would be greatly appreciated. THANKS Keep up the good work with all the informative articles.
  2. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    No i don't think it's possible.Just pull out the carpet.Line the whole tub.Drill two one inch holes under the seats.Watch out for vitals underneath.Then go buy two expanding plugs like for boats.No one will ever notice them under your seats.This way you can spray out dirt two.Don't spay under the dash.Do the standard waterprofing to the ignition.If you're sinking it up to the dash you might want to buy a boat to pull behind it.
  3. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Sure there is....just dunk it in a tank of rtv....pull it out...wait till it dries...then just cut the rtv away from the places you don't want it...[​IMG]
    Kidding!
    <font color=green>[​IMG]Eagle86K5[​IMG]
  4. Blazerbob
    Blazerbob 1/2 ton status
    214
    Western NY
    Just lift it higher and put on bigger tires so you will stay higher than the water! LOL
    <font color=blue>Blazerbob</font color=blue>[​IMG]
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Strip the inside bare and have is rhino lined from top to bottom. Then buy all new weatherstripping and use gasket goop on all bolts you have to put through the floor(i.e.: Seats) this will help but it will not be 100% sealed.
    If you have a cage that goes trhough the floor, leave it in and have them Rhino line over the bottoms. Maybe even leave the seat in and Rhino line over the bolts.
    Mike
    82 GMC Jimmy "Emmett"
    IN TOO DEEP Off-Road Club
