waterpump question?
Discussion in 'The Garage' started by hidesertwheelin, Mar 10, 2005.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    Do water pump bearings make noise before they go out. There is a intermitten whistling noise comming from my engine. I kind of sounds like a dry u-joint, except it keeps going when I am stopped. Couold it be the ideler? I have never owned a vehicle with a serpentine belt. Thanks for the help.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    With your truck off grab the fan. Try and move it up and down and side to side. If it moves your waterpump bearings are bad. You sometimes get a drip from the weep holes in the waterpump.
    Harley
  3. Can Can
    15,555
    156
    Cochrane, Alberta, Canada
    It could also be a sign that your alternator is going out. When alternators get weak, heavy electrical loads really put a strain on them.
    Do the "intermittent" whining sounds coincide with heavier accessory usage?
  4. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
    MAKE SURE TO DO THIS!
    :xmas:
  5. hidesertwheelin
    Nov 13, 2004
    782
    4
    Hesperia, CA
    It's a brand new alternator. The headlights and the radio and that't it. Is a stupid kragen alternator thought
  6. Can Can
    15,555
    156
    Well, have you checked for moisture at the weep hole on the water pump? That would be a sure sign of a ready-to-die water pump. In my experience, when a water pump goes, she goes relatively quickly. How long has this squealing been going on for?
    Before you get too focussed on one part I would suggest you take a close look at all your pulleys and your belt, too.
  7. Fierospeeder
    Fierospeeder Banned
    Sep 17, 2001
    315
    Illinois
    with the vehicle shut off
    remove the belt, and spin all the pulleys by hand besides the crank pulley.
    this will help you narrow down which pulley is causing noise.
  8. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    The noise from under my hood was intermitent and turned out to be a plastic idler pulley under the AC unit
    It siezed up solid when the bearing let go , may have been caused by lots of mud running last summer:dunno:
    I ended up replacing it with a steel pulley I found in a box at a scrap yard and now it all seems good
