We all know know about no safety beads on 16.5"ers but...
Discussion in 'The Garage' started by BowtieRed, Jan 17, 2004.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    We all know know about no safety beads on 16.5\"ers but...
    why don't they have a safety bead?
  2. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Re: We all know know about no safety beads on 16.5\"ers but...
    I heard the size was originally meant for trucks that saw a lot of use in remote areas (back in the day) No safety lip made it very easy to mount and dismount tires by hand...
    Rene
  3. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I think it's like the narrower rear axle. Who knows. People did a lot of drugs back then.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Rene
    Which quickly became necessary when they found their way off the rim all by themself. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  5. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Nah, they only lose a bead easy if they are run at low pressures. A lot of 16.5 tires are run at 45-80 psi...
    Rene
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Ever since I saw my friend lose a 38" TSL at 25 PSI I have been turned off to off road tires in 16.5". Other run them with sucess, no clue how that one managed to come off, but he was just spinning in the mud and it slipped right off. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Factory steel Chevy rims DO have a safety bead. I am looking for a set to put some beadlocks on.
  8. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    I was under the impression that none of the 16.5ers had safety beads. But why does it matter if you are putting bead locks on them anyway?
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    When you find a set of these mythical beasts, please share pics with us. /forums/images/graemlins/wink.gif I've read that safety beads can't be used on 16.5's because the bead of 16.5 inch tires is not shaped to mount properly if the safety bead were on the rim.
  10. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    We use 16.5s on our 3 company trucks. But as rene said they are running about 75 PSI. Never had one come off the rim and I have hauled some serious weight with these trucks. It seems to me they were not designed to be run low presure.
  11. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I'll snap a pic of the 16.5x6.75" stock steel rims I have. They do have a small safety lip unlike the aftermarket rims...
    Rene
  12. XtrmChevy
    XtrmChevy 1/2 ton status
    Jul 14, 2001
    148
    Finland, Europe
    Here you go:
    I hope it is visible?
    The hole rim made of two
    And the leftovers
  13. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    I had allway thought about putting a big long beed of weld all the way around the wheel(inplace of a saftey beed), then putting it on on of the huge lathes at school and turning the beed(of weld) down to make it all uiform thicknes and stuff /forums/images/graemlins/thinking.gif
  14. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Because the beadlock only goes on the outside. If you run beadlocked non chevy 16.5's you still run the risk of blowing off the inner bead (which isn't as easy to set on the truck). Starting with a 7" wide rim will get me into that 8 to 9" wide range that I am looking for with a bead lock holding on a fat TSL bead.
  15. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,002
    193
    Santa Maria, CA
    Lack of safety beads isn't the only problem with 16.5s. The bead surface also has a greater angle. I remember reading a safety bulletin in a tire store about the differance between 16s and 16.5s, I not sure, but I think 15,16,and 17s have a 10 degree angle while 16.5 have a 15 to 20 degree angle.
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you ever mounted a 16.5 you'd throughly understand that. They don't even really pop when you mount them, they just kinda slide onto the seat. Mount a 15 or 16 or 17 and you'll hear a distinct pop.
  17. JDNobodi
    Oct 9, 2002
    3,002
    193
    Santa Maria, CA
    I had mounted 16.5 before and they are a pain. The easist way is to have a air hose ready with a can of starting fluid and matches. /forums/images/graemlins/eek.gif
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Hey, whatever works. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  19. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Safety bead or not. The design of the 16.5 had two main purposes. To push the bead bundle to the edge of the wheel, and to ease in mounting on utility trucks (farms, rural USA, ect). There are some wheels with a lip on them, of sorts. This will hardly keep a tire on the wheel. I work for a large tire company and almost every 16.5 we get we can kick the bead off with a good boot. (The rusted ones are a little tempermental). This is why it is not called bead rentention or a safety bead. You could weld a safety bead (not recomended though) for more bead retention, but the heavy taper will still let the bead bundle move in. If you go to a real skinny wheel (6.5 or 7) and a good size tire (38" - 42") you can make it work. It is all in how much you want to work. You can work a little harder on the trail to keep your normal 16.5's full of air, or you can put in a couple extra hours a week at the job paying off those new beadlocks /forums/images/graemlins/grin.gif It is up to the owner's driving style to decide usually.
  20. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I have 16.5's and haven't had a prob with them but I only do mud and have never dropped below about 20psi.
