Weak 14B disk breaks mounts
Discussion in 'The Garage' started by 84CUCV, Apr 14, 2005.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I just saw my friends disks on his 14b. There is four nuts bolted to the housing with small spacer. Now, wouldn't it be stronger to have a full circle spacer? Also he has a hard line right in to the caliper. How can that be? I would think the caliper moves as least a little. Sorry for the ignorance on this just trying to understand.
    thx mike
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Never had a problem with mine
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Depends on the tension in the bolts and the OD & length of the spacers.
    Hard line can be used w/o a section of flex hose. The downside to doing it this way is that Fatigue will eventually break the line if an expansion loop or loops aren't put in the line.
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK so the spacers are not a big deal. Do you mean a coil so it can move a little? Thats the only thing i can think of to have one.
    mike
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    I think the full spacer idea myself. Thats why I went with DIY4x's brackets!!! They are very nice and come with all the hardware. Plus Kert is great to deal with!
  6. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thanks for the link. Does DIY have a website?
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    www.diy4x.com
    :thumb:
  9. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Also, hardlines going to the caliper make it a pain to change the pads. More than likely he'll have to disconnect the hardline and then need to bleed the brakes.
  10. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Thanks guys! :waytogo: mike
