weak link
Discussion in 'OffRoad Design' started by drivelineman, Apr 14, 2001.
  1. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    steve - say we had a th 400 trans 203 t case and the 2nd gen doubler down to a 1350 c/v shaft - to a dana 70 out back locked up and a set of 39.5 boggers what's the weak link in the rear section ? on to the front 205 t case front output 32 spline and one ton c/v shaft to a dana 60 locked up running 5:13's ? what about the front ? and do you think the weak link should always be the driveline? is there anything in your doubler 2nd gen kit that would be the weak link in this system ? thanks for your time- Jess
  2. BMRCCR
    BMRCCR Registered Member
    Mar 7, 2001
    33
    u-joint at diff in rear.
    u-joints in axles in front or hubs
    These would probably be what breaks.
    Ideally, we would all have fusible hubs all the way around.
    The doubler is plenty strong, something else would probably fail first. But as always, YMMV.
    Anthony
  3. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Fusible hubs would be nice, but they don't make em for a Dana 60 front. btw...I would like to know this as well. :)
    Boss
    <A target="_blank" HREF=http://www.boss.coloradok5.com>http://www.boss.coloradok5.com</A>
