weak power windows
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Jan 20, 2004.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    My power windows, including my rear are all very slow rolling up, and down for that matter. It seems like they are barely getting enough power, especially if the car is off. What could be causing this?
  2. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    MIne did that. I tok the panels off and cleaned the 15 years of grease build up in the tracks. Then I sprayed everything with dry teflon garage door lube. Now they are as quick as the wifes new van /forums/images/graemlins/grin.gif
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Grease the tracks up and see how much better they work. Spray silicone or WD40 works. If not, you may have to pop covers off and grease the rails the windows slide on.
  4. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    Does your batter guage drop a lot when you hit the button, IF so check all your grounds, that fixed mine.
  5. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    as mentioned, clean/lube the tracks and see if that does it.
    Check voltage @ motor and see what's going on. Sometimes cleaning connectors will help.
    Worst case, new motor (did 2 on mine), and WOW what a difference! Motors were about 35-45 on E-bay, but found 1 in town for about same.
    PIA to change, but sweet results.
    Mine used to slow even more in temps below mid teens!
  6. dyeager535
    26,979
    Not to be nitpicky, but I wouldn't recommend WD40 or silicone for something like this. Lithium grease is probably a better bet.
    WD-40 isn't a very good lubricant (doesn't stick around very well, and attracts dust, "WD"=Water Displacing) and silicone spray also doesn't seem to "stick around" very well. If you ask me, WD-40 has silicone in it. They both "act" similar.
    For something like a hinge that is easily accessed, maybe, but even then, grease will last longer.
  7. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Yea, i had sloooow windows, so i cleaned the tracks and lubed them up with lithium grease. worked great! (for about 6 months...now they're back to being rediculousy slow) "Ummm, just a minute officer, it's going as fast as it can" /forums/images/graemlins/rotfl.gif
  8. zach78k5
    May 14, 2000
    406
    Thanks, I'll try that
  9. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    dyeager is right.. dont use wd40 or lithium or silicone.. use window run lube, or "mini vent window lube" you can buy it at the ford dealer in a small squirt bottle, works wonders..
  10. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    /forums/images/graemlins/rotfl.gif mine are waaaay slow too. especially the colder it is. i will be cleaning and re-greasing mine here soon.
    but till then i just open the door to talk , its faster /forums/images/graemlins/thumb.gif
  11. mattjensen
    mattjensen Registered Member
    Jan 22, 2004
    6
    Ausitn Texas
    All..thanks for the advice.. I have the door panel off my truck now for the same reason. I put some WD on it but didn't know how long it would last. I will look for some run lube. Thanks again.
  12. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    Don't use grease it collects dirt just like WD40. I read a ton of stuff before I lubed up my table saw and everyone recommended Dry Teflon...It lubes but doesn't hold dirt... I finally found some garage door lube by the people who make PB Blaster and it worked great so I did my doors...even sprayed into the felt and it was 15 deg the other morning and its still smooth /forums/images/graemlins/cool.gif
