web page about removing the range box from a 203
Discussion in 'The Garage' started by cybrfire, Jan 23, 2004.
  1. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I've seen a tech write up on how to do this. Does anybody have a link to it? I can't seem to find it back.
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Not a real big deal unless you want to save the "lock" shift rod. If not, just pull the bolts, wedge it apart, and cut the rod with a recip saw.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    easy, PM me and i will explain it to you better:
    rmeove yokes, remove case bolts, push the roll pin out of the shft fork shaft so range box will come off chain case
    thats about it,
    lot sof needle bearings will come out when ytou pull parts off back of chain case for rear output, unlewss you clamp them, but oh well, you just are after range case righT? or rebuilding the thing ?
    or ?
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Do you need the rod for the doubler setup?
  5. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
