weighed my truck today....
Discussion in 'The Garage' started by RootBreaker, Nov 18, 2005.
  1. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    ok so i stopped at a place that sells mulch....
    asked if i could use their scale and they said yes...
    so I weighted in with myself in the truck....
    5060lbs
    what do you weigh?
    this was with truck, me (180lbs0, 15k winch (150lbs with mount), 12 gallons gas
  2. spincast375
    spincast375 1/2 ton status
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    84 Blazer; 454 bbc
    certified scale in Sep2005 = 5,100 lb
    no driver or passenger; no winch; no mud
  3. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    My 85 GMC muscle truck tips the scales at 3755 w/full tank o gas(truck hooks better with more weight in the bed :D )
    My 89 Chevy 4x4 is around 4200lbs.
  4. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    I want to get mine weighed. I don't think we have any mulch or gravel places around. Anywhere else? Will a semi scale do or is it not accurate enough?
  5. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    96 crew cab 2x4 longbed 250/4l80-e/14ff me and 200lbs of crap on average. 6500 lbs. :eek1:
  6. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Weighed my 70 K5 minus top, but plus 100+lb dog=4040lbs
  7. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    My '86 crew cab is 6500lbs last time I came out on the dump scale empty. And I was 10,000lbs last time I came out of the gravel pit with a yard & a half on board.
    Haven't weight the '80 yet, but I've cut alot of metal off already :crazy:
  8. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    the scrap yard bt me wants 10 bucks. :thinking: been wanten to see what she weighs.tommorow sounds good.i'll check back. :D
  9. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    82k10/6.2=5,900 4in lift 15x10 steel wheels w/35s.
  10. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    80 as a 2wd 3/4 ton truck with two full saddle tanks of gas, myself, and my brother inside weighed in at 5400 lbs
  11. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    heavy metal...
    My 74 K20 I no longer have used to weigh in at 6,280 lbs with the flatbed and crane setup on it,with not much gas in it,empty!..(including me at the wheel,I weigh 170 lbs.It had a plow frame too--with the 8'plow on it was well over 7000 lbs..I weighed in at 12,570 lbs once when I brought a detroit deisel straight 6 motor from an old bulldozer to the scrap place once.. :eek1: --still cant believe it didn't snap the rotted frame in two!.. :rolleyes:
    My 82 K20 weighed in at 5450 lbs empty,with a nearly empty tank--it has a plow frame,a 6.2 deisel,and an 8' stepside bed!..weighs less than I thought..its about 6000 with the 7.5 ' plow on it..
    The "lightweight" of the 3 is my 79 C10,with an 8' fleetside bed --It used to weigh 4800 lbs with the 250 six it had--now with a 305 and a few other things like tools in the cab it weighs 4950...all these readings were on a digital scale used at the scrapyard to weigh big rigs,it might not be 100% accurate,but I bet they are very close..
    I weighed a frame I cut up and junked a week ago on an old bathroom scale,it said 500 lbs,and they paid me for 520 lbs,I also had a catalitic converter and some other light stuff,so I think their scales are prettty accurate.. :crazy:
  12. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    My rig wieghed in at 5,880 with a full tank of gas, D60/14ff and 8" lift with 35's and a warn winch mount bumper with a 9,000lb warn winch.
  13. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Take some scrap to them... then you will get weighed for free, and get $$$ for the scrap.
  14. divorced
    Jul 20, 2004
    5,115
    Like the scales at a truck stop? Yes, very accurate. Watch for the different pads as you pull on and put the front on one pad and the rear on the other and you will get your front/rear weight also. You will be up close to the front of the scale where the speaker is.
  15. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    78 k5 1-tons 37 inch boggers 12000# winch big bumpers front and rear no doors or top with lard ass at wheel 5600#
    85 sub extreme body mods and shortend to 100 inch w/b 35 inch swampers same lard ass 3900# :D
  16. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    My crewcab hits 7K easy. Heavy rear bumper, GN hitch, class V hitch, headache rack, tool box, transfer tank, saddle tanks and a 40 gal suburban tank in the back, plus two spare tires. with all 4 tanks full it is one heavy mother!
