weight
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by scamy459, Dec 21, 2001.
  1. scamy459
    scamy459 Registered Member
    Nov 28, 2001
    5
    riverside ca
    how much weight can a blazer tow safely?
    If it has a skirt, or a motor, run it
    72 blazer 454bb, turbo400, 3/4ton running gear
  2. scamy459
    Nov 28, 2001
    5
    riverside ca
    thanks for the help
  3. JMZ
    JMZ Registered Member
    Dec 4, 2001
    73
    Gonzales , Texas
    Most vehicles have a gross vehicle weight recommendation (GVWR) sticker somewhere, That would tell you. But if it is like my blazer it is probably not on there anymore. Maybe look at a newer model blazer and go by that. What do you need to pull?
  4. highwaydevil
    highwaydevil 1/2 ton status
    Oct 6, 2000
    145
    Colorado
    I've pulled a 5k travel trailer w/o alot of trouble. If the trailer is longer than 20' or so, it will tend to whip the blazer around some above 55mph. (about). It also depends upon wind drag. (tandem or box).
