Weird 14 blot/D44 questions....
Discussion in 'The Garage' started by SchnorrCS, Oct 27, 2006.
  1. SchnorrCS
    SchnorrCS 1/2 ton status
    Oct 11, 2005
    368
    Loveland, CO
    I wanna run a 14 bolt rear/d44 front. I wanna run 15 inch 6 lug wheels. Or do you think it would be better to run 15 in 8 luggers? I'd rpefer 6 as that's what I've got. Will 15s even clear the drums on a 14ff? Thanks for the help fellas.
    cS
  2. SchnorrCS
    Oct 11, 2005
    368
    Loveland, CO
    Nobody?
  3. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    14sf or 14ff?
    14sf=6 lug
    14ff=8 lug
    Yeah 15's will clear the 14 but the d44 will require some :grind: to get them to fit...depends on the back spacing as to how much.
    I'm doing this setup right now.
    -Avery
  4. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    If you run under 3" of backspacing, you can run 15" wheels on 8 lug d44/10b stuff.
  5. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I'm running 2 3/4" backspacing so when I get the front finished, there shouldn't be very much I have to do to get them to fit. 15's clear the 14bff w/ drums fine.
    John
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    if u keep ur 10b 6 lug and get 6lug adaptors/spacers then u can run 6 luggers on the 14bff
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    You could also weld fill the lug stud holes and redrill to 6 on 5.5 and be done with it. I think willyswanter did this on a set of hubs (not for his rig)
    Ira
  8. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Not all 14sf are 6-lug many are 8-lug
  9. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    491
    New Hampshire
    X2
    The 14SF is ALL 8 Lug until the new body style in 88'.
    Also 8-6 lug adapters don't exist.
  10. sandawgk5
    Oct 28, 2003
    6,881
    Fixed it for ya TonyP used to make them specifically for this dilema:D .
    Ira
  11. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    You can still get them. Not worth it since new rims are so cheap but if you want you can still find guys that have them.
    -Avery
  12. SchnorrCS
    Oct 11, 2005
    368
    Loveland, CO
    My dana 44 is alrerady 6 lug. How can I make my 14 ff 6 lug? I haven't heard of anybody doing this yet. I'm getting ready to run 38s and I wanna keep my rims the same.
    Best bet is kinda looking like selling the six lug rims and getting new 15 inch 8 luggers. What a pain in the ass. Maybe I'll just run it on the 44 and 12 bolt till she blows!
  13. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    You could do that...or like we have said you can get some adapters...just going to have to search for them. I think I saw some on Pirate the other day and I know there is a guy on www.gmfullsize.com that used to make them...for the right $$$ I'm sure he would make you a set.
    Something to think about though is that your 1/2 ton 10b vs. a 3/4-1 ton 14ff is a width difference. So if you run a 1/2 ton front and a 3/4 or 1 ton rear the rear axle will be 2" wider so if you run the same rims the rear will stick out farther because it needs a different back spacing.
    -Avery
  14. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    actually they wind up about the same width... our trucks are setup to be narrower in the back...
  15. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    hmm thats news to me...
    -A
  16. sandawgk5
    Oct 28, 2003
    6,881
    Yep all GM rear axles are 3" narrower than their counterpart front axle:D. Same is true even for the duallies.
    Ira
  17. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    wait...not to hijack but then why can we run the same back spacing on the rims front to rear and they stick out the same amount?
    -Avery
  18. sandawgk5
    Oct 28, 2003
    6,881
    They dont.
    Drive in damp dirt in a straight line and you will see the rear tire tracks slightly inside the front tire tracks. There are several theories as to why GM did this but the general concensus is it makes the turning radius smaller.
    Ira
  19. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Oh, cool.
    -Avery
