Weird Brake Linkage Thing on Rear axle?
Discussion in 'The Garage' started by **DONOTDELETE**, Jul 25, 2002.
    I was looking at the K20 and there seems to be a valve up near the frame rail with a 2 bar linkage that goes to the top of the pumpkin on the rear axle.The rear brake line goes in this little valve then another one comes out of it the goes to the back axle like normal. It looks like when you hit a bump or something the linkage changes something with the valve. What is this? It's an 84 K20 that I am looking at buying. I had just never seen or heard of one of these. Thanks -80K20
  1. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    It's a load sensing proportioning valve. It varies the pressure to the rear wheels depending on the suspension position (payload). More load = more brakes.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    That's GM's early attempt at rear wheel anti-lock brakes. It's supposed to help keep the rear wheels from locking when the truck isn't loaded.
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Yeah, what HarryH3 said. When hauling heavy loads you want to have good strong brakes, the problem is when empty it would cause the wheels to lock up and the rear end to hop/skid. The get the best of both worlds (soft brakes unloaded, strong brakes loaded), they put a valve on the frame to feel the distance between it and the axle. If the distance was far, it is assumed the body is near empty and you don't need as much braking force, but if the distance was close, it is assumed the body is full and greater braking force is applied. It was an alright idea, but I have seen more in bad shape (rust/rot or damages because of location) than in good. If it looks OK, I would leave it unless all you do is haul.
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Everybody is pretty much correct on what it is. You will find it on almost all 1 tons.
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    This is not a GM only thing. A lot of pickup trucks have this same set-up on the rear brakes.
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    You mean someone other than GM makes trucks? Huh! I'd never have guessed! /forums/images/icons/wink.gif There hasn't been a non-GM vehicle parked in my garage in many years... /forums/images/icons/cool.gif
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    What the others said....../forums/images/icons/wink.gif
    My three K30's all have that setup. I believe the first year for that type of brake setup was started in '81.
    Never saw this stuff on the older K30's though.
  8. Can you easily by pass this thing? Thanks
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yes, you can. /forums/images/icons/wink.gif
    You can either remove that long bar-piece thingie that sits vertical....
    ....or unhook one of the brakelines on the top of the sensor-thingie up in the frame rail.
    I had an '84 K30 that had the hard line disconnected at the sensor-thingie at the frame rail. The long bar was still on it but I removed it because I added another 4" lift to the rear.
    Disconnecting this type of brake set up won't affect the trucks braking performance at all.
