weird electrical issue
Discussion in 'The Garage' started by K10ANDYKHAMNIC, Feb 12, 2006.
  1. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    I noticed the other day my dome lamp stays on real dim when the headlights are on and the floor light stays on also . When I open the door the floor lamp goes out and the dome comes on all the way .What is going on ? I have a tach and its lamp is out , I cant remember where I wired it to ,could that be the prob and causing this ?:confused: TIA -A
  2. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    is this in a later model truck?
  3. AV8
    AV8 Registered Member
    Oct 8, 2005
    45
    Winston Salem, NC
    I had the same thing happen to me. It turned out to be a dime that had fallen into my cigarette lighter. Took it out and lights worked fine. It also blew a fuse.
  4. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    You've got at least one bad ground. Clean ground connections, check continuity to frame ground as well as power. Definitely some voltage leak.
  5. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    It is in my 81 k10 . Ill check out the ground. I think it might be the door switch .It seems flakey .
  6. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I second the cigarette lighter.
  7. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    I havent had that hooked up for a long time ....
