weird electrical problem, need help please to get legal !
Discussion in 'The Garage' started by big d, Aug 13, 2005.
  1. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    i have a electrical problem. i have front and rear lites (when u pull out on lite switch), only side marker turn signals, and no rear brake lites, and no rear hazards. ive checked fuse box and lite bulds, and im in process of checking grounds. ive also replaced the brake lite switch close to the column. any and all help would be greatly appreciated. thanks in advance.
  2. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Might wanna check the switch itself?
    Oh and check the turn signal circuit as well.
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Turn signal switch in the column is likely fubar'd. Brake and Hazards are run through the column switch. They're not that expensive, but it is time consuming to replace.
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Mine went crazy. Turned out to be a short in the wiring harness for the trailer (pigtail). If you have one, you might want to check that also.
  5. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    multi-meter is ure friend. turn em on and check voltage too, then if nothing dissconnect batt and start hunting for resitance from there. when u findshort go back twords open till u find it. take patence but is easy if u have wire diagram.
    i have got 2 cars for free cause wire problems turns out 6pack and 2hrs later got it working fine. still have my 86 couger-runs great
    just stick with it ;)
  6. big d
    Oct 24, 2001
    1,236
    illinois
  7. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    does that mean u have done all and are looking for more ideas? we need feedback to help u
  8. big d
    Oct 24, 2001
    1,236
    illinois
    ive checked fuses, and bulbs. all where ok, im gonna start checking grounds and im going to purchase a test lite soon. i was just throwing this out to see if i could get some ideas or if anyone had this happen to them. if i find out anything ill repost soon. thanks.
