Weird feelings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Sep 7, 2002.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    I just bought the truck, when you drive slow, it feels like a wheel is out of balance or something, kind of like a warped rotor when you are stopping feeling, except im not stopping. It seems to be getting worse the more I drive it. I know it needs rotors turned and pads up front, but I dont think that would cause it. Any ideas?
    AW
  2. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    pull the tires off and check the studs sometimes they will wear out and you may think you have tightened up the wheel but it's still loose.Just a thought
  3. steve85fla
    steve85fla Registered Member
    Mar 27, 2001
    83
    palm beach county FL
    Wheel bearing is my guess, I would jack it up and turn/shake the tires.
    Good luck
  4. sxrxnrr
    sxrxnrr Registered Member
    Sep 6, 2002
    16
    Melbourne, Florida
    I am no pro or anything, but I had problem knda like that. It was the rotor, thing was the brake hose was so worn that it would let pressure in, but not so easily back out. Would stay clamped onto the warped rotor for a while after stopping.. More than likly thats not it, just thought I would try to help out.
  5. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Consider your ball joints too. Check them if/when you check your wheel bearings.
  6. bckinblk
    bckinblk 1/2 ton status
    Jun 12, 2002
    305
    bristol connecticut
    I once had a wheel bearing walk into the spindle and it felt kinda like what your explaining .The only problem was that mine heated up and seized itself to the spindle it was a major PITA to get it apart .Hopefully that is not your problem .Check your wheel bearings and make sure that they are not over tightened and check out all the front running gear .hope this helps good luck
  7. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    I think its the brakes, the truck isn't doing it today. I won't have a chance to do the brakes until next weekend, I hear its a pretty involved job.
    AW
