Weird grinding noise when decelerating
Discussion in 'The Garage' started by PsychoticDeadGuy, Sep 16, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    Ok, i asked this question a while ago and everyone told me to change the u-joints...so i changed the the whole rear driveshaft and new u-joints. the noise is still there...the tranny has enough fluid and so does the trans case. i am thinking it could be the chain in the np208...it only does it when i let off the gas...it could be a long grind or it could be on and off...help please.
  2. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    mine did that too and i shaved my gears.
  3. outlawtorn
    outlawtorn 1/2 ton status
    Jul 21, 2004
    365
    Box Elder, SD
    my 203 did that... I was told it was slack in my chain.
  4. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    grinding
    Mine did that allso, and it turned out to be the pinnon gear had come forward and was hitting the spider houseing when you took foot off gas. It was 12 bolt GM.
  5. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Mine did that with 12" of suspension lift. Put stock 56's & a shackle flip back there and it quit. In my case, it was improper driveline angles.
  6. PsychoticDeadGuy
    Jan 8, 2005
    753
    ok, my rear end is good. how much if any should i be able to turn my driveshaft while my tranny is in park...(tires off the ground)?
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Try putting the truck in neutral before you slow down and see if it gets better or worse or stays the same.
    Doing that can point you in the right direction
  8. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Mine is doing the same thing (NP 208) My shaft is too long, and on deceleration and braking hard I get grinding. I'm pretty sure it's coming from the tcase. I'm going to push the axle back for now and check the housing.
    Someone mentioned slippng chain? :thinking:
  9. PsychoticDeadGuy
    Jan 8, 2005
    753
    well, the easiest fix so far seems to drop the t-case down a little bit. i ran it with a 4" lift and i lowered the t-case down about 1/2" and there were no problems. well now i have instead of blocks, i have ORD zero rates, and shackle flip and a 14bff which raised my truck up about 2 more inches from where it was...i am hoping it is the driveshaft angle...i am going to make a new spacer for the tranny mount to bring it down about 1/4-1/2" more...i hope it will work...i wont be able to do this until monday so i will post up my story when im done.
  10. 81jimmyslt
    Jun 5, 2003
    1,643
    anyone else have any ideas?
  11. PsychoticDeadGuy
    Jan 8, 2005
    753
    i will make the spacers tonight and will either put them on later tonight or tomorrow and i will let you know how it works
  12. PsychoticDeadGuy
    Jan 8, 2005
    753
    well, i put some spacers to lower the crossmember of my tranny which in turn lowered my t-case and made the angle for my driveshaft alot better. the spacer was only 3/8" thick but there are no more vibrations or grinding sounds...i feel much better now about it. hope this helps out someone else...
  13. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Glad to hear! :waytogo:
  14. 81jimmyslt
    Jun 5, 2003
    1,643
    I moved my axle back 1.5" but I still have grinding on deceleration. When I brake hard it's awful, grinds so much.
    Any more ideas?
    I'm going to lower my t-case again but only use the spacers on the t-case.
  15. PsychoticDeadGuy
    Jan 8, 2005
    753
    its from the rear end coming up a little and screwing up your drivline angle at the t-case...lower it about 1/4-1/2" and it should go away.
  16. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    485
    Grand Rapids area
    It could be just from mismatched driveline angles, but it could also be that you have a U-joint maxed out for angle. When you decelerate, the back of the truck comes up and this increases the U-joint angles. You would be able to see shiny spots in the yoke ears.
    I was also going to suggest a loose pinion nut, but if lowering the T-case helped, that probably wasn't the problem.
  17. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i got the same thing wrong with my 205.i was thinkin maybe it was just a little slop in the gears and them just catchin up with each other. other ck5 members said the same.
